So I'm still looking for a 1100 engine... mine is still laying around in pieces...
What's the preferred aftermarket pistons? JE, Wiseco or? I see JE has big-bore kits, I'd love to go 3mm+ = 1216cc.
However I fear that new compression ratio (13:1) will be too much for street gas. Anyone knows if 13 will work on street gas? And how about heating? Will I need an extra oil cooler?
Wiseco makes the same pistons (3mm+ bore) but with compression ratio of only 12. That sounds better I guess...
But if 13 works, why not?
Also, I got confused about sprocket sizes. A bigger rear sprocket will make the bike accelerate faster right? And I will lose a bit top speed, right?
I drove a factory modded 93' honda cbr900rr, and there is no gsxr1100 that can keep up with it. I was amazed to see it in front, and even more when I drove it. It 'only' had different cams (part numbers???) and a different crank to clutch conversion ratio (longer actually, you could get ~70mph in first gear!!!). Wouldn't the longer ratio make the bike poor at acceleration???
flaco
90' gsxr1100 without engine...
flaco
