1 - 9 of 9 Posts
i have a 99 gixxer 600. the guy i bought it from put a 190 rear tire on and cahnged the sprocket. could the sprocket or larger tire cause my speedometer to give an incorrect speed. i ask because i was on the highway the other day with some friends. and since i knew how to get to where we were going i was up front. i thought i was doing about 80mph. but it seemed like cars were just wizzing by me. when we stopped i asked them how fast we were going and no one really payed any attention. any ideas?
buy a GPS device and mount it to youre bike it will tell you exactly how fast you are going its a bit pricey but if you're out and about and happen to come across a good riding place you can store it as a way point and if you ever forget how to get there just look at the way point on the GPS device. Or just have someone follow you again.
thanks PIKA, but were can i find one thats actually small enought o fit on the bike without looking bulky?
A 190 isn't exactly a great choice for a rear tire. Anyway, it is possible that the size is affecting your speed, and same goes for the sprockets. Sportbike speedos aren't accurate anyway. They will always show a speed a little faster than actual. Larger tire and a larger sprocket ratio will increase the error. You can get a speedo healer and calibrate it to fix your error.
very true. it was on the bike when i bought it. sucks in turning. i'll be going back to a 180 very soon. i'll check on that speedo healer. any suggested manufacturers?
Just search the word "speedo healer" on google. Then look for the best deal. I got mine from my local shop, where they hook me up with discounts all the time. Should be less than $100.
Yep. Just calibrate it for whatever percentage it is off.
i know scott at bluegauges.com sells a speedo healer
1 - 9 of 9 Posts
