Uh, you don't know what Desmosedici is? Seriously?
Not a HUGE ducati fan, but I'd have my left nut surgically removed for this one.....
200+hp, Moto GP replica...and not just looks. Chassis, engine, brakes, bodywork, etc...the list goes on an on. They had on at Laguna this year in the GP paddock....even better looking in person.
I remember when the first pictures were released...especially the team version...whew.....MSRP? A cool $65,000.00.
http://www.motorcycle-usa.com/Article_Page.aspx?ArticleID=3358&Page=1
DUCATI DESMOSEDICI RR Technical Specifications
Engine: L-4 cylinder, liquid-cooled, DOHC, Desmodromic, 4 valves per cylinder, gear driven camshafts
Displacement: 989 cc
Power: More than 200 HP @ 13,500 rpm
Torque: N/A
Fuel injection: Four 50 mm Magneti Marelli throttle bodies, 12-hole "microjet" with injectors over throttle, manual idle control
Exhaust: 4 into 2 into 1 - Vertical Exit exhaust/silencer
Emissions: Euro 3
Trasmission: 6-speed; Cassette type
Clutch: Dry multi-plate slipper clutch
Body: Full carbon fiber bodywork
Frame: Tubular steel trellis hybrid, carbon fibre seat support, aluminium swingarm
Front Suspension: Ohlins 'FG353' PFF forks USD 43 mm pressurized, with preload, rebound and compression adjustment, TiN coated sliders
Front Wheel: Marchesini forged and machined magnesium
alloy wheels, with 7 spoke design as GP6
Rear Suspension: Ohlins rear shock, with rebound, low/high speed compression adjustment, and hydraulic preload adjustment
Rear Wheel: Marchesini forged and machined magnesium alloy wheels, with 7 spoke design as GP6
Tires: Bridgestone
Front Brake: Two Brembo radial "monoblock" callipers with four 34 mm pistons; two semi-floating 320 mm x 6 mm discs, with machined flange: the same as GP6 wet race set-up
Rear Brake: 240 mm fixed disc, floating calliper with two 34 mm pistons
Fuel tank: Aluminium alloy
Dry Weight:N/A
Instruments:
New lightweight Corse electronic multifunction dashboard with LCD 'bar' graph tachometer, trip/odometer, anti-theft immobilizer, lap time measurement, oil pressure, fuel reserve, EOBD, clock, air temperature, rev counter.
Colors:
(1) Desmosedici RR: Rosso GP with a white number plate on the tail section
(2) Desmosedici RR "Team Version": Rosso GP with broad white fairing stripe.
A team sponsor decal kit will be provided with each bike.
Single-seat only
