i know they are pretty simple to install but where do you place em ? not much room under that tank...
how far from the petcock do i put em? whic ID size is best? and lastly how often do you change/clean the filter?
thanks in adavance for the help.... i may get the russel filters...
Just run them from the carbs with a 3" line going into the carbs,the other side running to the petcock.Give them alittle bit of a loop so you'll have slack to be able to lift the tank to get at the hose clamps,5/16 is the norm for the hose diameter.
Bobbychet
