OK guys,
I have seen endless amounts of threads on this mod, but I still have one burning question
..... Should I fit an inline filter after the crankcase breather hose to protect the reeds in the head from getting contaminated???
I have seen this sort of thing in a few discussions but can't make my mind up!!!
yo top... since I'm the person that makes the kit you've pictured, I'll be the first to respond. If you haven't already, follow the link in my sig to read the FAQs on my EBAY site. They explain in detail why the filter's there.
Basically, it's main intent is to keep the PAIR ports in the cylinder head clean (which, if clogged when routing the crankcase into the PAIR system, could cause all sorts of troubles). As a side-effect, the reed valves are also kept clean, but this is a secondary benefit
