1 - 2 of 2 Posts
Hi all, I have a 98 UK GSXR 750 W (first of the fuel injected models)
Hoping someone maybe able to tell me from personal experience here.
I did a ride of 500 miles on the weekend, going up country wasn't a problem, but comming back the signal fuse kept blowing.
After it went several times I switched off everything and kept riding. Only thing was every big enough bump the fuse would blow and I would have no clocks yet again. I guess it is a wiring problem around the clocks, or water in the clock housing?
Has anyone else had these problems and if so what was the problem and where does it lie?
I want to find it quick and get back out riding instead of fixing.
Cheers
Graham
Bearded Viking Admin...
Check the wires, there's probably some damage insulation somewhere - when you go over bumps, the wires touch
Look specifically at places where the wires bend sharply or go over edges
1 - 2 of 2 Posts
