1 - 20 of 25 Posts
I bought the bike used at 17k miles, he said he always ran regular gas, even though the manual says it should use a grade of at least 91 octance. Even since I took over, I drained the gas in it and put in 92 octane fuel with some seafoam. Should I be worried or is it fine. Someone on the forum here said that since it is FI, the electronic will always adjust the different fuels. Idk guys, I'm a noob.
Edit: I mean it does have an M-4 slip on with the cat delete (obviously), a K&N air filter, and a PC and the SET is disabled and wide open.
I dunno, was the bike pinging/detonating while you were riding it with regular unleaded in it?
I'm assuming that you do not know what octane is and how it works....octane is a rating of how resistant a fuel is to detonation. The higher the number, the cooler it burns and the more it resists detonation. It has nothing to do with being cleaner or making more power necessarily, especially if the bike is not tuned for it (more compression, advanced ignition timing, forced induction etc). In fact, if you use too high of octane for an engine that is not tuned for it, you'll get an incomplete burn and make less HP.
The most HP is achieved by running the LOWEST octane fuel you can get away with, without causing the motor to knock or ping....not the other way around.
To answer your question though.....the bike is fine.
It states in the k7 manual to 'use fuel of octane 95 or higher'. The suggestion to me is that 95 is the minimum octane to
be used. In Germany for instance you can get 100 octane fuel. In the uk fuel like Shell V Power is 99 octane I think, there are
others too.
Uses squid tentacles as a butt-plug
Removed because I look like an idiot:lmao
It be fine , aint gona hurt anything just drive it and start using higher octane . Usually if you run it full time with regular u may get a spark knock but truth is I use both in my L2 1000 and my old k6 600 lol no issues at all . Mostly high octane But plenty of times LOTS times actually i filled my bikes ( empty to full ) with regular from my lawn tractor and trimmer gas jugs and drove lol hell i even dumped mixed Gas with 2 stoke trimmer oil in my bikes when its all i have on hand but just few few liters to get me to the fuel station which will cause little bit smoke from the 2 stroke oil lol but i got full exhaust no cats so My bikes are perfectly fine i sold my k6 600 last year with 49k on it and i bought it with 17k which i still see it around lots runny great . But The only reason i use my mower jugs some times is when taking off for the day when the fuel light comes on when im on my way home late im too lazy and tired too stop at the gas station on way back so lots times i pull in my garage with not much left in tank and i live a little ways from fuel station so i always got mower jugs filled sitting in the corner lol so yeah it be fine
You read Wikipedia incorrectly.:fact
1. detonation is an explosion. If the bike wasn't detonating it wasn't running.
2. Ocatne is the measure of how HIGH of compression before detonation
3. Higher octane fuels, while they don't burn "cleaner" usually contain better detergents which help keep your engine cleaner.
4. Not an expert in the field but higher compression=more force from detonation=faster rotation=more power....
5. Yes if your running a bike on a significantly higher octane than regular (specially ordered) you can damage internal components due to high compression and a more "violent" detonation.
You’re correcting someone that has forgotten more than you know. Lol
Likes to race old junk.
Let's clear this up.
When discussing spark ignited internal combustion engines, think of detonation as any uncontrolled ignition...rather than all of the air/fuel mixture in the cylinder, combusting efficiently at the right time, in the right place, with the propagation of the flame front ignited by the spark plug...little pockets of air/fuel mixture explode(think diesel), with random chaos.
Octane is the rating of the fuel's resistance to detonation.
We don't want detonation...a little makes a rattling noise and less power, a lot of it will hurt parts.
:banana:thumbupAnd now I know
To me its still seems higher octane would burn hotter and I know for a fact they put more/better detergents in higher octance fuel ( at least here in the states) which in turn cleans your engine better...
Yeah.... he also tried to school the forum (most authoritatively, I might add) about the false equivalency of 'motors' VS 'engines' :lol
Currently using pedals..
Even after everything that has been said, why would you still think it burns hotter? Higher octane also doesn't imply better fuel additives. Look at Toptiergas.com and you'll see that this isn't a new thing, nor is it exclusive to any certain octane level in order to have quality fuel additives for the health of our fuel systems and engines.
So what your telling me is it burns cooler due to it being able to withstand higher compression? I'm not being an asshole here im actually intrigued and learning alot from you gents right now.
Here is an example of a piston that was damaged by excessive detonation. It causes pitting in the top of the piston. Too much detonation over time will cause a piston to fail.
Damn I had no idea.
We know
I'd recommend you tone-down the 'forcefulness' of your opinions and insults to members of the community. This wasn't the first time.
Yea pretty sure this was the first time I "insulted" a veteran member of the community. Also pretty sure you guys have a no crying rule here seems like that went out the window with some of the members. I believe this is the first time I've also provided incorrect info, which I'm sure you've never done:thumbup That and the fact that I whole heartily admitted I was completely wrong and removed my post.
I'm one of those idiots who puts 93 in everything I own thinking it was better haha dammit I should have done some research now I have no clue what I should be putting in my bike......Or my vehicles for that matter....
Octane is pretty simple. Measured in two different ways and different countries may have different numbers, but essentially the same rating. Octane is the resistance to ignition. The compression in your engine heats things quite a bit. Larger cylinders compress the air charge and create more heat. That's why the 600 uses the lowest grade just fine, the 750 is usually mid grade, and the 1000 and bigger use the premium. Any quality fuel is going to have the additive package. I'm pretty sure Shell has the same additive package on all three grades in the state, but only market it for the premium grade to try and drive people to buy the more expensive fuel (even though they don't need it).
You want your spark plug to ignite your mix and nothing else. Ignition timed so that the flame kernel has time to start to grow and build pressure before the power stroke starts. This way, the pressure in the cylinder has the most time to push on the crank and produce power. That's a gross oversimplification.
Thanks brother :cheers
1 - 20 of 25 Posts
About this Discussion
13 Participants
JamesIsMe
Full Forum Listing
