what does this mean? it is much easier esp when it is this hot outside, to start up when it is "cold" rather than re-starting it after it's already been warmed up. the engine turns like it should... it just takes longer to catch. Any thoughts?
you get different plugs for different temps
also if its very hot and fuel is thrown into a hot cylinder it will vaporise so not allowing it to ignite as easy
If the motor start easy when the motor is cold, and not when hot... I normaly is a rich thing... The cold motor needs more fuel to run..
thanks guys... i'll check my air filter and let yall know if anything changes.
EDIT: i just realized... it's about time for a general tune up including checking valve clearances... i know THAT has ALOT to do with startup. i'll keep yall posted.
[ 08-17-2002, 10:27 PM: Message edited by: nowkeg ]
