awesome gonna go out a try shifting tonite!
the whole point of this tutorial is to use shifting as a easier way to hold wheelies.......not to give you more rpms to chase your wheelies.... just wanna clear that up.I can't shift standing up, but I stop at 4th sitting down. By 4th i'm going to damn fast anyways. Also, I USE the clutch when I shift. I shift on one wheel just like I do on two. I never give wheelie advice to anyone...I dont want to hear "but you tole me to....." once they loop.
thx for the writeupgixxsexR said:wish i could hold em up like that all day in the vid. good stuff. all that squirrlyness though still gets me. i havnt tried shifting yet.
+1...mcook said:That is a very good write up and must have taken some time. I'm plenty of people will put the info to good use.![]()
OKay So you want to learn how to shift in a wheelie Ill make a lil tutorial
Purpose: There is more than one purpose on shifting in a wheelie.
- Gain more rpm: Some people are at the point where there wheelies are constantly redlining, mostly because they're are chasing their wheelies and instead of gonig higher in a wheelie to hit balance point a alternate way to hold your wheelie just a tad longer can be to shift gears and you gain more rpm thus giving you a few more seconds to hold your wheelies. Doing this is fine..... some people dont want to bring the wheelies higher cause they're not use to the height yet......
- Have More Throttle Play: As you should know the higher the gear you are in the easier it is to play w/ the throttle..... 1st is more twitchy than 2nd and 2nd is more twitchy than 3rd and so on. For some people they like to have alot of throttle to play with because its obviuosly more easier to control and apply small throttle increments. Applying small throttle increments is key to keeping your wheelies in balance point...... you dont wanna be jerky and you want to be as smooth as possible. Itll definitly be weird to get use to at first but you will get use to it and find it know how to shift? Example to do a 3rd gear wheelie.
Things You Need to do or be ready for before trying:
Shifting in a wheelie I highly recommend NOT to use the CLUTCH, i repeat I HIGHLY recommend NOT to use the clutch. Yes it is possible to do it with the clutch and some people can do it with the clutch and to risk wearing down your tranny a little bit than fucking up your bike completely...... Stunting will harm your bike more than regular riding...... accept that fact
HOW TO SHIFT WITHOUT CLUTCH
- well there is a proper way of doing it and if you do it correctly it wont hurt your tranny. and yes you may practice this with both wheels on the ground. Go a speed your confertable with ... maybe 30mph in 2nd gear??keep the throttle steady and put your foot on the shifter getting ready to shift and right when you let off the throttle thats when your transmission will be open to go into the next gear.... a good way to get the feeling of it first is to apply small pressure on the shifter, not alot ....if your grinding the gears thats too much. Anyways apply small pressure and let off the throttle.... it will fall right into gear....... when you think you got that down you can do it at faster speed.... and also try it in 1st to 2nd gear cause thats where it might go wrong since you might slip into neutral.... but its really not that hard......... no more than 1 minute of practicing that and you should get it.
PREREQUISITE for shifting 1st to 2nd gear (sitdown)
- Should be able to ride 1st gear wheelie to redline... not absolutely neccessary but i reccomend it and thats how i learned it.
- Got your no clutch shifting down w/ two wheels! obviously![]()
- No throttle jockeys, i dont recommend any twitchy first gear wheeliers to shift gears yet.... learn to ride 1st gear relatively smoothly...... you dont have to be that high, just be smooth.
PREREQUISITE for shifting 2nd to 3rd gear (standups)
- Should be able to lift up 2nd gear standups constantly
- I recommend you know what 2nd gear balance point feels like or at least know what the throttle feels like when its near balance point (throttle should feel light and you should be feathering the throttle to keep it up in 2nd) why i say you should be at balance point is because 2nd to 3rd gear shifting shouldnt be about having more rpm to spend..... it should be about saving rpm and keeping the speed of your wheelies slow 50-60mph ish.... the reason for this is 2nd gear can hit 100mph on most bikes..... if your hitting redline 2nd gear standups , dont you think your going too fast already??? your goal for 2nd to 3rd is too bring up 2nd gear and shift 3rd gear straight into balance point and you should be adjust to the throttle since you have more play.
**SHIFTING 1st to 2nd in a wheelie
okay now that you know what you need and what to expect i can explain what to when shifting in a wheelie
- So you go the speed you do your regular 1st gear wheelies at (5-35mph)
- I suggest power wheelie so you gas on , gas off, and gas on again... Itll come up smoothly this way
- Keep your foot on the shifter and apply real little pressure.... if you have reverse shifting just rest your toe on the shifter so itll be easier to shift when your in the air.
- Once your front wheel comes off the ground, let off the throttle and at the sametime shift into 2nd gear , dont even bother riding out 1st gear at all....... its simple just lift the wheel off teh ground and shift into 2nd right away.
http://www2.hawaii.edu/~kuroyana/Files/shift.WMV
Remember you dont have to be at balance point when shifting, THis is the height im at when i shifted into second
Okay chances are you wont get it the first time, or the second or the third for that matter.... here is somethings you might of ran into
-most common problem is you slip into neutral. This is because either you didnt bring your wheel high enough the ground due to you bring up the wheelie slow
To solve that try to hit the throttle harder when you bring it up in 1st, when you do this the bike will still have the momentum of going upwards even when you shut off the throttle.
The other reason you hit neutral is your not clicking it hard enough into 2nd...... remember apply pressure on the shifter before the wheelie.....and make sure you have your clutchless shifting down.
-Another problem that could happen is that you click it into second gear but when you got on the throttle again you slip into neutral..... This has happened to me alot...... i think its part of the tranny thats going bad but you - Another problem you might run into is you manage to shift into 2nd gear but you just dont got enough power to keep it up..... GOOD you got it to shift into 2nd gear!! thats a important part..... you just gotta get a tad higher and make sure your shifting is efficient and FAST.... there can be no lag when you let off the throttle to shift gears....... its Gas up to bring the wheelie up , let off throttle and shift gears, and get on the throttle again all done within a split second.... only practice can help you out on this one.
**SHIFTING 2nd to 3rd in a wheelie (STANDUP)**
Okay so you wanna know where the funs at??? its in the 3rd gear standups
Again like 1st to 2nd gear wheelies you shift into the next gear pretty fast.... but you may want to shift it right at balance point cause the purpose of this is to save RPM and keeping the 3rd gear wheelies slow right?
- Bounce or Clutch your 2nd gear standup wheelie up pretty hard.....
- Make sure your foot is over the shifter ready to shift into the next gear and when you get near balance point let off the throttle and shift into 3rd at the same time.....
- I like to bounce up 2nd gear hard...... so when i shift into the 3rd gear the bike is still floating upwards and has the momentum of going up still.... .
Not much can go wrong here...... if you cant keep it up in 3rd you just gotta go higher and give more gas....
you cant miss shift becuase there is no neutral between 2nd and 3rd.....
just remember you want a quick shift80mph.
http://www2.hawaii.edu/~kuroyana/Files/2ndto3rd.WMV
here is a picture of the height im at when i shift into 3rd gear....
Well mods please sticky this.
And this is just a rough draft.... i have to wait for your guys replies to see what i need to fix and add on so post away.
