Need to replace the seal on my shifter rod on 2001 750. Can someone tell me if this can be done without removing the engine/splitting the case?
Thanks
How bad is the oil leak? I changed mine on my 03 1000 by mistake thinking I could put it back in. It was truly a brain fart as it’s not designed to be replaced w/ out taking engine apart.
The only way to do it which is pulling it out and grinding the case till it’s round, then installing it and putting JB weld to build it back up. The good news is there isn’t oil pressure there.
good luck!
Discussion Starter #6
good luck!
Thank you!!! Very helpful!
