Evening all.
I have a 2013 1000 fitted with a shift power electronics package.
Yesterday my quickshifter spat its dummy and refused to assist with shifting. It would then start intermittently cutting spark.
I think it’s the switch but it only became a problem when I adjusted the height of the shift lever.
does anyone know the correct distance of the shift rod so I can set the shift height correctly and hopefully stop this annoying problem?
Thanks In advance.
Can you post a photo of your set up? My install knowledge is with Translogic and Healtech, but the principles are the same and I'd like to analyse what you've done.
No problems will do when I’m next with the bike. It’s parked up at the minute as I can’t use it.
