I'm trying to set the fuel level (floats) on my 87 1100 and can't get consistent (repeatable) measurements. If I check each carb (one at a time) then recheck any one of them, the measurement can vary up to 2mm from the original measurement. 2mm is the total tolerance (0-2mm below bowl flange). The subsequent reading is taken without changing anything except moving the hose from one carb to another. I have checked them with the bike cold, warm, running or not with the same variation. The needle & seats have normal wear but look good. The bike has always run good; I'm just trying to tweak it to perfection since I ride it daily (and wouldn't have it any other way!!)
The bike has 44K mi; the motor is original/stock except for: K&N ovals, V&H SS2R pipe & ignition advancer, and has been jetted. I bought the bike with 18K and it had already been jetted so I don't know if it was a kit or DYI (the needles have no marking).
Any suggestions?
you have to replace the float needles...as they rotate in their seats...the "wear" area changes between the seat and needle..thats why the level changes....
I was afraid someone was going to say that ... any suggestion where a set of 4 could be had for a reasonable price??
