I thought I'd mention after disabling the SET value and bike seems to be running well. I can tell that while it's lost a small amount of instant low down torque the throttle response now feels smoother and more linear which does make the bike a bit easier to ride on the road.
Oddly the bike seems to make less popping sounds at higher revs when you throttle off as well, which means it's nicer to keep the revs higher in normal riding.
How do you pick up low RPM? Do you add numbers to your tachometer?
