Service manual pdf for real!!!!
19671 Views 9 Replies 9 Participants Last post by  Jakehardman1980
Ok this is crazy and annoying at the same time. I have found over a dozen links on here that claim to have a download for the service manual. However every link is a dead end. Does anyone actually have a link or could someone possibly email me the manual.
I am having electrical issue with my 07 gsxr. It started and ran fine Saturday. The chec f1 displayed after about 10 minutes. It still started and ran fine until my 4th stop. I went to start and got nothing it acted like the bike was not in Nuetral. I was able to bump start it and ride it home but no restart after. I did put it in dealer mode and got the -c00. I know the bike does not always like to start with the kickstand down at times I have to put it up to start it but now 90% of the time I get nothing. When it does start it will run for about a min then shuts off. I can rev to keep it going but when I let of it stalls again.
Thanks in advance for any suggestions. I have read and searched a lot and am leaning towards replacing the gps first. I will have the battery tested. The service manual is needed for the steps in testing the rectifier and stator. My gsxr experience is starting off bad unfortunately, as I only bought the bike 3 weeks ago. I have a 2000 yzf 600r, and for the past 5 year I never had a single issue with it.
1 - 10 of 10 Posts
The manual link everyone used is now gone,havent found any replacements yet. Your bike is having quite a few of the symptoms that the regulator/rectifier&stator all need replacing. The year bike you have is notorious for that,especially when bought used.
If you plan on keeping the bike,you could always spend some money and *buy*a factory service manual from Suzuki.
I have seen a rectifier relocate to get it away from the rad. But is there any upgraded part suggestions for the rectifier and stator. If I end up finding out that that is the problem I would rather spend a few extra dollars to get better parts. I am going to search for the diag procedure but if anyone knows the values and procedure for testing these two parts or even knows location of the write up please leave info for me.
motodataproject.com worked for me.
Thanks Cody!
in case anyone's looking, here's an always working link for 750 2006/07. This isn't going to show up on any search engine - hopefully I'm not violating any forum ToS.
  • Like
Reactions: 2
so I just joined gixx'r lyfe and having some regrets.. all the years - I had to the join the 07 squad
Not all heroes wear capes thank you and love you lol🤣😂
Check the Tip over switch in the tail section had similar prob thought it was reg. Rectifier, turned out when the last owner had power commander installed the shitty shop cobbled the wiring up and the Tip over switch came lose and under hear would cause the bike to shut down till it cooled off. Just like the regulator rectifier would do when going bad. Check that just a suggestion.
[/QUOTE
1 - 10 of 10 Posts
