Does anyone know how to seperate the lower fork ends that hold the brake calipers (not sure of correct name), from the fork stanchions of the 750 USD forks. I can see a tiny little hex screw but not sure if removing this will work???
I'm pretty sure they're peened in I've thought about doing this and swapping for a set of radial bottoms from newer set that's bent. Post up if you have any luck getting them off. They had to be put on there one way or another.
