hi
I have a gsxr1000 l3
Suddenly the right side signal stopped working front and back and the light right turn signal from the dashboard .
when I press the hazard lights only the left one turns on .
The left signal is working but the right one nothing at all .
If anyone can help me I’ll appreciate that
Thank you
Could be in your switch but 1st, I would check the wires in the nose going to the fairing... If that checks out go to the tail, check all the wiring as best you can to make sure nothing is bare or pinched and or grounding out somewhere... If you can positively make sure wires are good it's going to be the switch, you can also make sure no wires have been pinched right at the switch, issue could be there as well... Hope this helped or you have already made the fix... Ride safe!!!
It’s already at the shop getting fixed .
Thank you for your reply .
Why this happen ? What’s the reason that makes this issue and can we prevent that from happening in the future?
Thanks
Thanks
What did the shop say is the problem??? Then I can possibly speculate...
