2014 gsxr1000
Not sure what happened, was riding the bike..everything fine (Highway). I do ride the bike hard..never rev limiter type but def put the gears theough theire motions. but thats what there built for..no? Anyway once i noticed my right boot soaked with oil i pulled to check that the oil was fine through the sight glass after a 10 12min cooldown it was. It was right where it should be so i continued home. Once at slower speeds i noticed comong put of 1st amd 2nd there was an engine rotation type of flap around noise. Then I did feel a slight vibration in the footpegs and grips but bike made it home fine. Im gjessing the worst. Thinking maybe a crankshaft problem an hopefully not a journal bearing problem or something. Thank you for anything.
Loose oil filter?. All you can do is try to look around for the leak yourself. We can’t see it. Take things apart and get a close look. (y)
Some type of liquid ? Did you ride through a puddle ? Smell, will tell what it is. Petrol, oil, water/glycol. Brake fluid, fork oil, These engines are made to run up to redline every gear. At 12,000 you know your alive 😁
Post in correct sub forum 12-16 GSXR 1000
