OK, this is wierd
Just recently, I've noticed that at certain revs, my tank vibrates
When the gas is low, its more noticeable than when its full (damping), so I only really notice the vibes every so often.
I long ago lost the rubber pads, but have only recently noticed the vibes.
Anyone else have this, anyone have a cure ?
i had this ,when i checked i had lost the rubber blocks /pads off the side of the tank ,obviously when i lifted the tank ,so i checked in the garage and found them ,it was ok after
Replace the side pads on the tank, and also check the grommets at the front where it is bolted down... then you should be vibe-free!
TG
TG
<font size="2" face="Verdana, Arial">Ahhh - I'll try that - mine has been pad-free for bout a year - I lost them, and put a finishing edge there - but the tank grommets are kinds worn - I'll drop into the parts dept next week....
