1 - 12 of 12 Posts
Then you either:
a) Didn't properly install it. Specifically the installation and adjustment of the STPS
b) Have a problem in the SDTV system other than the STVA.
+1 The code will go away if the problem is fixed and power to the ECM is turned off & restored, something that you doubtless did while working on the bike. Try looking at the description of the code in the service manual for the specific conditions that trigger it.
Then you either:
What's the sdtv and stps I'm no mechanic sorry
And that's why you're having problems.....
Suzuki Dual Throttle Valve
Secondary Throttle Position Sensor
Discussion Starter #6
Then you either:
Check the stps when that's not right I get c29
An incorrect installation of the STPS will not always trigger a C29, but will always trigger C28.
Discussion Starter #8
The lines match up if I move it I get c29 move it back to match lines up get c28
Put on stva connected the stps so blue lines match connected battery turned key c28 moved stps got c29 moved lines back got c28
What position were the secondary throttle blades when you installed the sensor?
Page 5-19 of the service manual - STPS is installed with the secondary throttle valves fully open.
Discussion Starter #12
Even with the new one fitted there shut so I've rang garage and there taking it in Saturday thank you for your help
1 - 12 of 12 Posts
