what part of ot are you trying to remove? I wouls just take the arm off the splined shaft going in to the motor, then unscrew the shaft from the lever. One side is reverse thread, but I don't remember which.
the aluminium rod that connects to the shift lever assembly, its attached or seems pressed in like a ball and socket, seems like i could just pull on it to pop it out but i guess it could also be removed by unswcrewing...
guess ill find out when my new one comes in.
