Sorry if this has been asked before but I tried searching and surprisingly can't find anything. I need to remove my OEM Steering Damper as its destroyed and I don't want to replace it with factory. Does anyone know what resistor is required to be soldered in and where I should be installing this?
Thanks,
Jeff
Here or here. Ohlins makes one (21702-01) but it's probably expensive. There are probably others. I assume that they all use the same connector but make sure first.
You say you searched?
Thanks BillV, ya I searched but I must have done a terrible job. I can't buy the part cause I broke the connector but am hoping the resistor route works.
$18 resistor fix, thank you sir! Now to just find a ohlins dampener for the right price.
