This is going to be a really dumb question, but why does my red light always turn on, it’s on from the moment the bike is on. Can it be from having the cables removed on the servo motor? I did change the oil and coolant too
I do have an FI, would that be the reason for it? I had the cable on the servo removed because it didn’t work anymoreAn FI light? Is it a low oil pressure light?
Can you put it in dealer mode and get the code for the light? That usually leads to a fix..
Um, you pretty much answered it yourself.I do have an FI, would that be the reason for it? I had the cable on the servo removed because it didn’t work anymore
Oh alright lol. ThanksUm, you pretty much answered it yourself.
Sounds good, thanks for the helpTo have the FI not flash up you will need to remove a wire from the ECU it’s a simple job just have a look on YouTube for guidance 👍
ExhaustPlease educate me, what servo motor ?
I’ll be doing it very soon then, should I put a servo buddy on?There'd also be an oil can icon displayed if it was low oil pressure. But it's almost certainly due to fiddling with the EXCVA. Putting it in dealer mode should show a C46 error. Note that the bike will be in fail-safe/reduced power mode until that's corrected. The void left by removing a lead to the ECM should be plugged.
Yes the servo buddy is what you need installed. It worked flawlessly on my bike.I’ll be doing it very soon then, should I put a servo buddy on?
