Rear shock rebuild ( tight budget ) k-tech spring and oil change. Does anyone know how much\ type oil goes into the rear shock. The foam bumper that is on the damper rod, where can I get one or what is it made of. Thank you.
I think they are also gas filled there is a company on ebay that charge £120 to rebuild your shock if you post it to them they're in the uk
Srad 600\750 oem rear shock "showa" full service or rebuild can be done by competent owners. Full seal kits available from k-tech, bump stops etc. Shock oil\fluid would be your choice.
