Somehow my rear shock reservoir got loose and hit the wheel moderate speed, when i pulled over the hose that connects to the reservoir was lose, the banjo bolt was unscrewed and oil leaked all over the wheel. I falt bedded it back home and just tightened the banjo bolt back to stop the leak. Now i have 0 pressure in the rear and im wondering if i should throw the whole shock in the bin or if i can DIY a rebuild ?
  1. What shock do you have on there? Year? Oem? Pictures? All I can gather about the shock is it has a flat back. ? I asume its on an oil cooled bike because of the section you are posting in but I could be wrong. A little more info would help. Do you have a manual?
Hey dave a have a manual and everything but the thing is the oem shock i had before this one had a valve and everything, when it got toast i discarded of it and bought this one which i think is off a 750, had it configured to my weight and everything, but i currently have no pics
