1 - 10 of 10 Posts
Hello . On my GSXR 1000 , rear brake rotor is so hot avter 10 min raiding that cant even tuch with hand .
I checked that there is no dragg on wheel . Wheel is moving free . If i will use brake wheel does not moves but as soon as i stop pushing brake pedal , wheel is free .
Also i tryed to drive without rear brake and after ride the rotor was cold .
So the result is that there is not any wheel cach or drug but when i am using brake after some of use rear rotor is very hot . What could be the reason of it ?
How did you notice this - just decided to randomly touch the rotor or is the thing glowing? Use more front brake, you barely need the rear anyway.
It sounds like you're only braking with the rear, which is incorrect except in unusual circumstances. If anything, you should only be using the front.
I'm confused, are you riding around smashing the rear brake to stop? And why are you touching your rotors to begin with, that's just weird.
umm I learned my lesson many years ago, NEVER TOUCH YOUR ROTORS! I have a scar to prove it today.
They get burning HOT, its supposed to, lol
Soak your rotors and pads with oil to reduce friction and keep your rotors cool.
Both Handsome AND Pretty!
OP, where are you from?
1 - 10 of 10 Posts
