Hello if i will set yoshi racing cams on GSXR1000 and then tune with commander and ignition module how much hp gain minimum and maximum withoit any other work in engine ?
What Year of GSXR1000 and what type of cams ? ( You can use 07 cams in 01-06 if you move the campin and also use newer ( 09-16 ) in older if you know how to...
That is not nearly enough information.
Uhhh, need more details. Ported Head? Is it milled? Compression? I'm assuming you are asking about a K3/K4 model right?
Just use the web cams that Jason mentioned. Thats a solid gain!!
Whatever cam you use, make sure you get springs too.
