Hey guys im about to revalve another set of forks. Forks on my 02 750. Anyhow, any of you run the extenders?
This relates to the shock eye to eye question i presented earlier.
If you are running this, what do you run the rear at.......??? Much longer.
Are the fork extenders a "must"
Suppose you could extend the wheel off the ground and measure the inner tube and compare to some stock forks.
I decided against extending my forks, don't think its needed by me and i can't get the parts at cost so i will pass this part of it up.
1000 springs are the proper stiffness for my weight .90 and the valving up front, along with the Fox rear i should be good.
