07 GSXR
I have a 2007 gsxr 750 and was wondering if a set of race fairings from a 2010 gsxr 750 will fit my bike?
I've seen several riders put 2008 fairings on their 2007 and believe the 2008 to 2010 are the same.
Thankyou for your help ahead of time
07 GSXR
I like the race fairings for my 07 but the 2010 set I'm looking at is in better condition.
So the 2010 fairings will fit or no?
I cannot say 100% as I don't have either bike or plastics, but all information leads to the only change between the gen 3.12 06-07 and 08-10 is;
"revised headlights, new colors, multi-mode power adjustments. At the rear wheel"
fact is all 5 years are listed as "gen 3.12" so that would indicate they are very much identical, no aggressive upgrades..
my guess is any difference in body work will be at the headlight which won't matter to you as race has no headlight anyways unless its endurance.. you can visually see teh difference in the headlight on comparison..
the fact guys are saying they are using 08 on an 06 is a good indication they cross, if you're apprehensive call the place you are buying from and ask if the part numbers are different or if they cross over? bout all you can do unless someone chimes in and verifies.. takes a while sometimes.. from what I am reading it looks good but I just looked at the 2 models and headlight shape is very different so if you were counting on that no..
actually the headlight is radically different, and it appears the ram air inlet is different, that doesn't mean the ram air tubes are different or wont work but inquire on that as well you will need those, a lot of race kits you get new tubes..
the seller should know all this, maybe hit a racer forum if you are in a hurry and need an answer?
I would give a Suzuki dealer a call & just ask them to check if the part numbers are the same, what ever you do don’t buy the cheap copies on EBay that are from China they are awful.
07 GSXR
Discussion Starter · #6 ·
After reviewing the fairings, everything with fit but the headlight in which it must be mounted a different way. Looks to me that a small adjustment would need to be made to accomodate the headlight.
All in all, all looks good!
thankyou for all your help!
