Dano's Performance Suzuki GSXR Quick Shifter
Dano's Performance now offers this complete Quick Shifter package for the Suzuki GSXR 600 and 750 (2001-15) , GSXR 1000 (2000-15) and GSX1300R Hayabusa (1999-15) models. Typically 3 yards (9 feet) can be gained per gear shift by using our Quick Shifter, so this is a must have item if you are racing. This unit allows full or part throttle up-shifts without the use of a clutch. Microcontroller based design utilizing our own custom firmware which means this is cutting edge technology. This is a stand-alone unit in which no computer is necessary to operate it. Fully adjustable delay range of 35-80 milliseconds can be done in 5 millisecond increments via a 10 position rotary switch. The electronic circuitry only allows the Quick Shifter function to operate above 4000 RPM's so no false triggers can occur when the bike is at low speed or when trying to locate neutral. We offer both pull and push type switch configurations for standard or reverse (GP) shift patterns.See our website at: http://www.danosperformance.com/Suzuki GSXR Quick Shifter.htm
Most Quick shifters are designed for clutchless up shifts as this one is also.Does nothing to assist down shifts. Thanks Dan
