Hi all, I recently installed a HM Plus QS to my K9 / L0 / L1 GSXR 1000. And i wanted to know what kill times you all use? TIA
I had a HM quickshifter on my previous bike and used 60 ms.
The Translogix I use now is set on 63 ms i thought.
You can start a bit higher 65/70 If you feel it's to long that shorten i a bit, but i won't go to low.
I believe mine is set at around 65ms from 1st to 2nd and it works its way down to 40-45ms from 5th to 6th.
I also have one of these race cut shift stars as seen on the right installed on both my bikes so the shift times are slightly shorter (it recommends to set the cut time slightly less on each gear when using these).
Hi, it depends on what kinda rider you are. If its for road use, or track.. check out youtube, thats how i got mine right. I used to get bad 'kicks' from my gear box at high rotation. Theres some great videos on that quickshifter, explaining what you need to know to make your own settings according to your type of use. Cheers
