Do you guys put a drain hole in your bellypans? What do you use for a plug? Any advice to help me out on this is greatly appreciated.
Thanks
Before you drill.
Go to your local hardware store or if a friend works in an automotive dealer and go through the plastic cap bins.
You can find just about any fitting you want and get a dozen of them.
One hole in the front for under braking draining and one in the rear.
Don't go smaller than .25 as rocks from the track will gum it up.
Try for a hole of .50 but keep checking as you drill the hole out with the fittings you purchased.
If the stopper doesn't fit well tech will fail you.
About this Discussion
3 Participants
REM6A
Full Forum Listing
