1 - 9 of 9 Posts
I'm setting up an ECU based quickshifter for my friend's K6 600 and I would like to know what are the minimum safe kill times people use. I can set the kill times based on gear and rpm, see the attached photo.
Bike has oem shift star and we're going to use a Cordona strain gauge sensor. It would be nice to get a baseline setup to start with before the first track day. Thanks!
Generally a 60ms kill time is what a lot of them are set to by default.
But
80 > 70 > 60 > 55 > 50 I think is what what Bazzaz sets theirs by default by gear. I shorten mine slightly because I run a race cut shift star that makes efts a little quicker so kill times can be shortened.
^Thanks!
I think we'll try something like this:
1st 80ms 1000-18000rpm
2nd 70ms 1000-7000, 65ms 8000-18000
3rd 65ms 1000-7000, 60ms 8000-10000, 55ms 11000-18000
4th 65ms 1000-7000, 60ms 8000-10000, 55ms 8000-18000
5th 60ms 1000-7000, 55ms 8000-18000
If I remember correctly, those high kill times will cause an FI light. I think I had mine set 60-55-50-50-50 and it worked well.
^Yeah, I've read about that happening with Bazzaz or any other "dummy" QS. But with ECU operated QS it shouldn't be a problem and I can also disable coil FI codes if necessary.
I had the Bazzaz...
I just double-checked my Bazzaz QS "map" file that I have on the 600, it looks like.....
65 --> 55 --> 50 --> 45 --> 40
I have something similar on the 1000, but that one uses the old BPD QS4. Both have the same shift star, no FI lights.
I have recently fitted a quick shifter to my K7 600, and I am having the fault code issue, you said you can disable the coil fault code? How can you do that?
1 - 9 of 9 Posts
