could someone tell me what is the "normal" oil temperature? i have -91 (oil/air cooled) gixxer and oil temp raises at max 80 degrees... is that normal?
You said 80 ??? Is that in celcius?? If so, that is perfectly fine. Oil fails at about 115 C. So if your oil ever gets that hot it needs to be changed.
yes is it 80 degrees (celsius). Maybe it is normal. in summer temperature raises about 100 degrees, but now there is -5 degrees outside... I think overheating is no problem until next summer
