anyone ever do a 5 speed conversion on a 750?i ive seen u guys talkin about puttin 6 speeds in 100s so can i do the oppsite? I drag race my bike which is turbocharged and the gear spacing is 2 close.will a 5 speed fit? along with the 1100 clutch assembly? i dont know if the drive gear on the crank is the the same tooth count as the the 750 but does anyone know if it will work ? im tired of clutches lasting 6 passes having to leave at 9000 rpm to spool the turbo and slipping the clutch ..no one i know makes a lock up assembly for a 750 so if a 1100 basket will work ill do it everything is readily available for 1100 ....any one up to the challenge? any help will be appreciated.....steve
[ 10-06-2002, 08:31 PM: Message edited by: gsxrturbobike ]
YAAFM Mod
It should work as long as you use a GSXR and not a Katana trans. I have never heard of this being do though. just us the pre 90 trans to avoid having to convert to a spring clutch to use the lock up.
Bones
