I've got a gsxr1000 k7 and since Monday it doesn't work. When you push the start bottom you can listen the starter relay but nothing happens. I took it out and it works when you connect to a 12v. But when I put it on my bike it doesn't work. I have charged the battery and I have checked the starter relay, sometimes it gives 12v and sometimes it gives 4 or 6v. Do you think that the problem is that relay?? Once the bike give an _C40 error, but only once and I don't know if it is because of this problem
Thanks
Thanks
