My 93 750W will only run on prime. The petcock is new and the vacumn line is not clogged. Any ideas?
IM THE BRONZE
Put a piece of fuel line on your petcock, disconnect vacuum line and draw a vacuum on the vacuum line with your mouth.
See if it flows in the "ON" position.
If it doesnt, you have a petcock stuck diaphragm issue. If thats the case, you'll have to pull the cover off the back of the petcock and free up the oring on the diaphragm plunger.
Thank you for the suggestion. That helped me pinpoint the problem. The diaphragm was taken apart - reassembled and put back on the tank. It now runs great in the 'On' position.
