1 - 8 of 8 Posts
I purchased a bazzaz fuel unit an zafm controller, I hooked it all up and now the fuel pump does not come on and the motor will not turn over, any suggestions would be appreciated. I have checked all the fuses they are fine.
Check your harnesses and power/grounds when you installed everything. Doesn't sound like fuses.
I have disconnected everything still did not work. I am not throwing any codes. I have power to the bike dash an head light comes on, but motor will not turn over.
Does it try to crank and turn over or nothing at all when you hit the starter?
Check kickstand switch and clutch switch just to be sure they are tight and secure.
You're not getting power to the bazzaz. When i installed mine i had the same problem, in my excitement and haste i tied into the wrong wire for power, it acted exactly like yours until i tied into the right wire. Also double check your ground.
1 - 8 of 8 Posts
