im tryiing to bleed the rear brakes on my srad and for got the correct rotation. Do you bleed from the inside caliber first to the out side or at same time. What is the fastest way to bleed them? do you pump the brake while it is loose or do you just hold it in and tighten then pump. Please help Ive done it a few times before never had a problem. Just cant remember how I did it thank alot..
..............bleed them one at a time..put the bleed hose on the nipple, pump the pedel...hold the pedal down and then loosen the fittting till the pedel bottoms out..hold the pedel down and tighten the fitting..do this on each nipple (hmmmm nipple) till theres no air bubbles in the line..
the valve is opened until the pedal or lever bottoms out, then tighten the valve and THEN let go the pedal/lever. if you let the lever/pedal go before tightening the valve you will suck air into the system..
