1 - 14 of 14 Posts
Ive had a idea, to increase the power of petroleum distilate machines.
Once a tubo charger is fitted to feed more air into the engine, add a small compressor to the gas tank thus forcing more juice through the pump/intectors to mix with even more air and hey presto another 35-40 bhp
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by FastCat:
Hey, if you could get like 4 or 500psi in the tank, you could prolly eliminate the need for gasoline all together... like one of those airplanes they sell at wal-mart...<hr></blockquote>
They sell airplanes at wal-mart!?!?!?!?!? I have gots ta have one!!!!
Well, you can always put another straw on the top of the tank so you can blow on it and pre-presurize the tank.
Discussion Starter · #6 ·
another idea was to feed a straw from the exhaust to the tank, then the harder you rev the bike the more power you get.
Backfires could cause a problem though, might need a flash back arrestor of some kind.
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by wild child:
<hr></blockquote>
why dont you feed a straw from your arse to the tank ? then eat lots of curries .
Discussion Starter · #8 ·
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by gsxrster:
<hr></blockquote>
imagine the conceqences if you were to follow though, the carb clean bill would be horrendous
<hr></blockquote>
just fill it with Lager
<hr></blockquote>
You are making this too complicated. Just tap off the ram air ducts with a few strwas and connect them to the tank overflow
BAM! preasurized airbox and fuel tank
Oh, I forgot, you also save yourself some weigh since you wont need the fuel pump
Discussion Starter · #12 ·
i had thought of that, but figured starting the bike could be a problem. Youd have to have a compressor to pressurise the tank to fill the carbs or every time you tried to start it or slowed for any reason it wouldnt go
normal larger or that Scotish Tennants super shit??
<hr></blockquote>
Tennants......sorts all sorts of problems.... hic
1 - 14 of 14 Posts
