My limited understanding is that Bazzaz controls all injectors whereas PC only half (1 per cylinder). PC has more maps and better customer support. What's your real-world experience with these?
PC will control all injectors if you buy the add-on fuel module. That being said, I really didn't notice any improvement with a Bazzaz and the 8-injector control versus the 4-injector control of the stock PC.
I had a powercommander on my K-6 when I bought it, had one on my old 01 Busa as well, and let me tell you, nothing compares to a CPU flash. Night and day! Just my 2 cents.
I bought a 03 gsxr 750. The previous owner did "Special modifications" that I'm working out. I replaced the rectifier, stator, battery, fix wiring, kick stand sensor, radiator with an 05 gsxr 750. The first problem I had was the bike took a while for it to start especially when it was cold...
End of track season wash, inspection, and oil change. When I have all the body work off, I heat it up before oil change to watch the expansion tank and do a thorough inspection. A few normal things needed to be addressed, but there's a tune problem. #1-#3 were reading all within 20 degrees...
Apologizing in advance for improper thread / previous post because I haven't been on a gixxer in 9 years, but I just nabbed myself a k7 750 and I have a question. Here goes...bike has a yosh R55 full system and a PC3 preloaded map. Got new Michelin 2CTs, (190 in the rear vs stock 180) and...
I recently added a midpipe and a PC5 to my 2018 750 and I obviously went to get it dyno tuned soon after. The business I went to has been in service a very long time and they are fairly well reputable for previous dynos. After everything was said and done, I only had to pay 159 dollars which was...
I have a 06 gixxer 600. I have installed a pc5 but I'm a lil unsure about the last connector on the pc5 I believe it's the one that should connect to the o2 sensor. Well wen I connect that one the bike runs shitty and is burning gas really rich intake it off it runs better but still I'm not...
