1 - 9 of 9 Posts
I'll say thanks for the help up front, it's appreciated
I bought a 1992 GSXR 750 for $500. Not running, no key, carbs not on it and apparently an ignition issue.
Here are my questions/issues:
1. I expected round headlights and this has a squareish headlight. Must be aftermarket
2. I cannot identify the fairing, is it aftermarket? I need a rear cover for it but, not sure which one to get.
3. The carbs are 36mm Mikunis (I measured the inside engine side bore). They don't seem to match the bike. The inner carbs are spaced to the boot but the outside ones don't. The bike has a push/pull throttle cable and these carbs don't have that type of linkage.
4. What carbs would work on this bike? (Size, year, model)?
5. What carbs would be best?
6. There is a Vance & Hines ignition pack on the bike. Is that stock?
7. Would an engine from a 2001 GSXR fit this frame without cutting the frame? I can make brackets and do the wiring and what is necessary if it is possible and a good idea.
Thanks again. I just want to get the bike running so I can hand my CBR125 to my wife next year to learn on and I have a fun bike to ride.
-Those are definitely not OEM fairings or headlight for a 750W.
-Standard OEM carbs for the 750W would be best unless you're modding the engine
-V&H parts are definitely not stock
-Fitting a K1 fuel injected 750 into a carb'd '92 would be quite the project considering zero parts are interchangeable and you'd be engineering and fabricating every step of the way.
I can live with aftermarket fairing and headlight for now.
I was told the engine was bored to a 883 which would mean it was bored 6mm in diameter larger, this seems a bit much. Would stock carbs be suitable for that with jets or, could I use GSXR1100 carbs?
You say the swap would be hard. Fabricating mounts would be no big deal but, would the 2001 fit? Wiring is easy but if the mounting and fitting is a nightmare, I will forget about it.
Thanks again.
Generally speaking, liquid cooled and air cooled engines are best swapped in their respective frames. The engine are configured differently and it makes swapping them a headache, or in some cases impossible. You also have to consider how the motor sit in the frame as well as aligns with the rear sprocket. I've never tried it myself so thats all the info I have but I'm on multiple motorcycle forums and they all advise against trying to fit a water cooled engine in an oil cooled frame and vice versa
That makes sense. I will forget about an engine swap and try to locate some carbs locally in order to get the bike together. Thanks for the info.
Juvenile Thinker
Where are you located? If it's a 1992 it's not a US model water cooled 750 as they were oil-cooled, the 750Ws didn't make it here until 93. In 92 we got just the 600. Could be a Canadian model...or could be a 92 600 frame with a different motor since the frames were basically the same for the 92-93 600, 93-95 750 and 93-98 1100
Not stock, not sure what it came off of, but you should be able to find a part number on it somewhere and google it.
Looks like an Airtech Yosh front kit (with the headlight cutout and added) and possibly an Airtech SRAD tail kit, though I thought those were all one piece without a pillion?
Stock (California spec) was 36mm, but with push/pull linkage. Non-California was 38mm. Perhaps off an earlier oil-burner? not sure if they had push pull cables, though I'm fairly certain they did. The spacing issue could be the boots installed in the incorrect locations (they are specific), or the wrong boots since OEM parts are getting harder to find.
Whichever carb you fit and jet. You can use the Mikunis in 36 or 38, some go with the flat slide TMs, there are others available as well if you search.
The ones that work lol...see above
If it has a brand name other than Suzuki on it...it's not stock
No. Two different generations of bikes. The biggest difference is that the later motors are suspended, where the W motors sit in a cradle. You would end up reworking the entire top half or the frame just to fit the airbox/tank/carb body/injectors, as well as clearance issues with exhaust, radiators, etc. Cheaper to buy an 01 frame to put the motor in.
Discussion Starter #7
I am located in Canada, that likely explains why it is water cooled.
I will take a closer look at the boots and see if they are installed properly.
The bike currently has a push/pull throttle cable assembly, is that stock? The carbs don't have that type of connection though. I am pretty certain that the carbs are not meant for the bike.
Post a pic of the push-pull throttle;the OEM has two throttle cables...
If it indeed is an 883cc it very well may have had some aftermarket flatslide carbs which do require an aftermarket push-pull..should be easy enough to determine if we can see the assembly
Discussion Starter #9
The throttle cables are push/pull. I think the proper carbs were swapped with something else when a shady mechanic was "fixing" it for the previous owner. I will get some more pictures after work today and post them.
1 - 9 of 9 Posts
