thecount said:
sorry but what does ptv stand for?and should i get adjustable cam gears if I
decide to have the head plained or do the thinner head gasket.and what would i have to have
the cams degreed at?
PTV is an abbreviation for Piston To Valve clearance. Something you should come to terms with
before embarking on this journey. It shouldn't be an issue if you keep the stock cams and put
them back properly.
Also you should mill the head instead of plaining it, unless it's a racing one made of wood.
Adjustable sprockets would be a waste on stock cams and not really needed for thinner head
gasket or milled head. Now is your opportunity to upgrade the cams.
You will get better results from a thinner head gasket, the reason is it reduces
the squish as well as a biger volume change, unlike milling the head. Milling the head by
0.01" might decrease the volume by 1cc = +0.5 compression point.
So for the best do both! Just pull the middle shim out of the stocker.
I wonder if a single shim gasket will seal? Hummm.
Yosh is around 0.014" and the stock ~0.026" (squished).
