Those aren't reflectors. Those are my lucky "daily traffic avoiders"...
Pipe sounds freakin' fantastic!! Nice n' deep right up until you pull the throttle back and it screams it's head off...
I got that undertail from Indysuperbike.com . It's just your basic Hotbodies undertail. It came with license plate brackets, but I decided to scrap them. I just bent the top of the plate and drilled two holes into the very bottom of the undertail. There's plenty of room if I need to give some 300lb chick a lift and we hit a pothole
I do not currently have a light on mine, but I was thinking about picking up a set of these and bolting them to the bottom corners of the plate... Lite n' Boltz
I have a set- only problem you'll have is that the wire is kind of short- you'll have to run extra wire to the brake light, especially since your plate is "so far" from the tail section. I couldn't bear to drill my undertail so I'm still uning the stock undertail, but have the same one you have- I realized that I also had to intergrate some resistors for the turn signals too. I had some problems with my install- didn't fit completely flush, it seemed too tight of a fit (too small) at the end near the battery box section. Did you have the same problem?
I was just stating that they were my lucky charms as of yet. I've had some close calls in town, so I figured I'd leave them on for superstitious purposes.
