748 d.ot head on 1127 N, couple of things preventing me from completing the build,
1- carbs wont go in the boots not even with ratchet strap. (Yes they are the correct boots, spacing on carbs is a bit off, might dremel boots)
2- fuel tap is hitting the carbs from what i can foresee, what if any solution do i have other than running a pingel tap, and if thats the only option which pingel have u guys used, there seem to be many options, i need the one that will work.
Cheers guys
Cheers guys
