1 - 11 of 11 Posts
Viking Fan Club Merchandise Manager
any of you guys have something to protect your pegs when you grind them? mine are starting to grind up pretty good. my coworker has some kind of metal piece that goes under the pegs to protect them. im not sure what they are. anyone use something like this and where can i find a set?
Bearded Viking Admin...
Do they have a little slider bolt screwed in like on sportbikes? If so you could just put in some short, regular bolts - or you could drill and tap them if they don't already.
ill take a look and see. my coworker had these triangle pieces under his. i didnt get a chance to ask him about it. he did mention it to me a week ago that he bought them somewhere but he isnt around to ask right now.
The metal pc that goes under them are more of a replaceable gage to give you an idea of where you are at your lean.
Can you get your pegs up on a higher notch?
Seems not:
I'd wait until they are worn down, then change them to some that have slider bolts.
...or get a bike with ground clearance :lmao
Discussion Starter #9
i dont always grind the pegs so its not a big deal but i do have some nice scrapes on them now :biggrin
i have a couple turns on my base that grind my pegs pretty good. basically its a right hand turn at a stop sign going upwards on to a small bridge. i also grind every now and then on roundabouts but thats rare and im not worried about that. shaft, yep im looking for something like those peg savers!
That’s Mister Moderator Chalet To You ....
body position is the most obvious solution to your problem but I wonder what proper BP looks like on a bike like yours :scratch ?
Discussion Starter #11
sitting on the bike is the only position :lmao
the pegs sit low so its normal for cruisers to grind them.
1 - 11 of 11 Posts
