1 - 18 of 18 Posts
same here to bad you dont own a gixxer
translated.
sameo hero paco. you no own correto bikeo
Seeing as though the throttle tubes are compatible, maybe the switch housing is as well?
I doubt the wiring harness connector would be the same, but if the housing was similiar, you could swap out the wiring and resolder the connections.
Are you looking for a complete new (to you) assembly, or are you replacing one that got damaged?
I'm just thinking - if you have an old gixxer housing around - it might be worth taking a look at fever. Might be able to make it work just fine. I really don't know though. That's just the cheap in me shining through.
I'd give you one if I had it
I'm replacing the busted one so anything will do i was hoping for an r6 one but i don't care really...
Go down to your Suzuki dealer, Honda dealer, whoever dealer and get a toggle switch. those OEM stock switches are bulky and a waste. Unless, of course, you need your signals and horn for track use...
Discussion Starter · #13 ·
and what the hell do i do about the start button? obviously you have done this before so help a brother out
ideally, you don't need the start/stop switch - so you could just eliminate it entirely (hard-wire the contacts together). But race rule requirements could likely mandate that you have an operational kill switch. Better check on that.
Discussion Starter · #15 ·
if it was up to me the thing ould have been long gone, but it is mandatory to have a kill switch
Hey pal you sig needs to go BYE BYE...Mucho Pronto...
why is that??
Bike is wrong make/ model ya fuckstick...Y else would I bust your chops...
1 - 18 of 18 Posts
