Been a while...
Hurt the 1146 so... decided to "go big or go home" !
79.5mm bore x 65mm stroke.
Fresh , just couple heat cycles...
Cheers
M.
Damn! That exhaust note is music to my ears :drool
If you would,can you give some details on the build and your anticipated numbers at the drag strip.
What was your best E.T. & trap speed with the old setup?
The 1146 got hurt, too much timing and lean condition burnt the pistons and damaged the head. never had the chance to have a good pass on spray. Ran 9.90 on motor with my 275 lbs a$$ on it. Learnt a lot from my mistakes and more...
The 1290...
79.5 bore x 65mm stroke = 1290 cc
30 in / 27 ex downdraft head work by Jeff.
Dished custom nitrous pistons by JE.
5 mil crank worked by Jay.
11.8: cr
Mallory 110gph fuel pump feeding motor & spray.
I'll put up pics tonite from home...
That should fly:cheers
Thats gonna be a beast,thanks for the pics :thumbup
