don't strip them just sand them. the ethylene plastic will absorb the stripper and the paint will not stick. pull off the decals, remove the adhesive left behind, sand with 600 grit, prime and paint. most companies make a plastic adhesion promoter to help the paint stick to the plactic. if you're using urathane you probobly won't need it. the tank is metal so have at it with the stripper, uumm... paint remover.
