I'm unfamiliar with this bike but aren't the codes the suffix of the various part numbers? For example, for the front fender on model M (hopefully that means something to you) the blue is 0NE (Parsec Blue No. 2) while for model N the blue is 1LE (Pearl Suzuki Medium Blue). I see 0JW (Pearl Still White) being used elsewhere. If a code doesn't "exist" (3SR, E95, etc.), it's because the associated part has multiple colors and the code is for that combination - very common with decals. For later years, the parts fiche includes tables where the component codes for parts with multiple colors are listed.
This isn't all inclusive but it's a good start.
This provides more, including the multi-color component codes, but it will take some wading through. Note page 69.
Much appreciate it for all the help BillV.. Ill check all paint codes for the 92 model carefully and see which one match with my colours.
Cheers,
Stavros
