Hi all! i've noted a strange behaviour of my 750 '93: when i switch on the headlights, the temperature indicator goes up visibly and the minimum RPM ad idle speed goes down a bit (50-100 RPM less) and vice versa when i switch off the lights. Few mounths ago (i've this problem since i've bought the bike) i changed the coolant; i suppose the old liquid was simply water with no coolant added -or it wasn't been changed for a lot of time- because it was dirt and dark but luckily it doesn't seemed to be contaminated with oil. Obviously the problem is still there -i suppose it's an electrical problem?!
Moreover i don't know if the fan works in the right way: it usually starts when the temperature indicator is almost at the red level and in this case it does it's job pulling down the temperature but sometimes (when it's very hot or i'm stuck in traffic) it starts when the temperature indicator is already in the red level and it's not able to pull down the temperature, unless i switch the lights off.
During the winter it not seems to be a problem because the temperature hardly goes up to the higher point; instead now with hotter season i have to switch off the lights eg when i stop at the traffic light so that the indicator turns down again.
The big problem is that in these case i don't know what is the "real" engine temperature and i'm afraid that this could cause damage to the engine.:frown2:
Anyone with similar experiences? Any suggestions?
